Desert Champions Trophy - 2021
Leaders Lead - II - Learn to lead the desert drive - 16 Oct 2021
Congratulations @M.Seidam @Hisham Masaad and @Shaz Shah  for successfully completing the first session of leaders lead with flying colors.
As you all have learned the basics first and demonstrated a perfect way to lead an independent drive in the desert, now it's your chance to work on the routing and planning skills.
You will be learning the basics of leading the convoy in the desert in three different steps:
  1. Advance sand reading, plan your lead, plan your exits.
  2. Use of navigational software for selecting the right course of path.
  3. How to systematically scale the lead for all the cars in the convoy.
In this second session of leaders lead you will be leading with the help of off-road navigation app or device. You can choose any device or app (motionx, gaia, mytrail etc) and mark these basic points and you will be required to reach any one or few of them:
  1. Entry and Exit
    1. Solar Park
    2. Al Qudra Desert
    3. Opp Bab Al Shams
  2. Mark long range playable dunes
  3. Mark pylon tracks, cycle tracks
  4. Mark as many sabka, flat track or easy exits in case of emergency
  5. Mark fencing or restricted area
  6. Mark technical dunes
P.S. I will personally check each of your device to verify and help you further.
Approximate Area Perimeter
Drive Details
Level: Selected Advisors only (M.Seidem, Hisham, Shaaz)
When: 16 Oct 2021, Saturday
Meeting time: 4:00 PM, (Sharp, without any exceptions)
Meeting Point: https://goo.gl/maps/QcWUZQnkeyw6U8QF9 Solar Park
Approximate finish time: 08:00 PM
Please RSVP on the below calendar:
7 hours ago, Chaitanya D said:
@M.Seidam, @Hisham Masaad and @Shaaz Sha please go through this thread - tons of information there.
You all will do great, best wishes and see you leading drives soon.
Thank Dr. @Chaitanya D, one day was in the office 6 am , no one is there, closed the door, and went through one by one 😄
@Hisham Masaad, yes luckily you had time at 6:00 because it’s well known you’d NEVER check the forum while at work ;)
good luck with the drive ! I am counting days before I can drive under your lead !
Subscribe and then join Offroad Club
And enjoy multiple level off-road drives - every weekend.
