JL Modifications impact on Warranty
  • 4 weeks later...
There is no one answer for the warranty cases. But the general principle is - you don't lose a warranty for the car itself, but only warranty issues related to your modifications can be rejected. E.g. after your modifications, general electric issues can be rejected, but if you have a chassis issue - should not be a problem
On 10/29/2021 at 12:02 PM, Vaibhav said:
Hello,
Just wanted to check if any one in the forum has information if there is a kill switch installed and a pedal commander does it impact the Warranty of the vehicle?
Regards
Vaibhav
The pedal commander should not void the warranty, since its not an actual modification.,  Just an add-on.
For the kill switch, what is the switch killing?
