Prado traction control
Rob S
Hi,
was on absolute newbie drive this week and both I and another Prado driver faced traction control activating even though disabled by the button on the dash. Any advice for us how to fully disable from other Prado owners? Both of ours see 2015 models.
@Mikhail Lukichev @Kalahari @Antoz
tagging few Prado owners to see if they have faced issues with this.
As Kalahari probably means:
Pushing it once disables traction, but if you keep it pushed for a couple seconds more, than TRC OFF will also light up.
15 hours ago, Rob Soughton said:
Hi,
As advised already, you need to keep the button pressed for several seconds. Two off lights should appear on the dash. However, ABS will be still on (which is fine for me).
Thanks!
Thanks everyone, tried this morning and is slightly different than the video so thought worth documenting for others if relevant.
press once, “TRC off” lights up.
press and hold:
“TRC off” light is displayed almost instantly
” ‘image of  skidding car’ and ‘off’ “ then appears after 3-5 seconds
I’ll try this on the next drive and report back!
  • 4 weeks later...
