Absolute Newbie Desert Drive - Al Qudra - Dubai - 10 Dec 2021
Frederic
15 hours ago, Vijay Cowlagi said:
Hi Frederic
I am so looking forward to this :)
I have a 2014 LC 200  stock vehicle with no changes / modifications
I took a master class with Brette and a recovery class with Ricard Last month.  That is about 3-4 hours of experience
Good morning @Vijay Cowlagi
As you have completed 2 personal trainings already, you can sign up for a Newbie drive (if you have all your gears), and you do not need to attend this Absolute Newbie drive. (i noticed you signed up for Brette his Newbie drive already).
 @Tareq Al Turq @Myles Keague @Ryan Tan
Welcome to Carnity Offroad Club !
@Markus B thanks for your introduction in the meantime.
Kindly introduce yourself and provide the following info:
1) Which 4x4 are you bringing ?
2) Do you have any Offroading experience ? If so please specify.
3) Is your vehicle equipped with front and rear towpoints (the factory ones are fine) ?
For your first drive there are a few minimum required tools:
1) Pressure gauge and deflator, so you can deflate your tyres when you arrive.
2) Air compressor to inflate your tyres again after the drive.
If you have more offroad gears, such as your walkie talkie, shovel, offroad flag, you are welcome to bring it along.
4 minutes ago, Myles Keague said:
Thanks @Myles Keague. The nearest gas station is at Last Exit Al Qudra, but either you will be in a long queue or it won’t even work at all.
On 12/5/2021 at 2:04 PM, Frederic said:
Good morning @Ryan Tan and welcome to Carnity Offroad Club  !
This evening, the drive will go live, and you will be able to RSVP.
In the meantime, kindly introduce yourself and provide the following info:
- Toyota Prado
- only once with friends’ help
- i think there’s one at the back not too sure of the back
I have prado 2012
I dont have offroad experience
I have all the requirment needed. Shovel. Woki toki and pressure guage and air pump and deflators
Tow hook for the car rear and front are stock
@Frederic I have done absolute newbies 3 month back in my earlier car - Renault Koleos (2018) with earlier subscription (which got expired)
Now I have upgraded to Jeep Sahara 2021 - 4 door with stage 2 modification, but would like to start from the basics again and like to join this drive.
I have done RSVP for the drive but please confirm would I be able to join the same.
Hi @Rajat Verma yes i see you have completed 1 Absolute Newbie drive before. If you have changed your vehicle, it might be indeed be not a bad idea to join this drive.
See you on Friday !
Thanks Frederic. I will join Brette on the newbie drive.
