Best Phone Holder?
Mark D
Without any doubt, after many trials, RAM Mounts. Specifically designed for off-road, they are simply perfect.
I have the magnetic one: a small metal disk glued on the back of the phone cover and you can attach / remove your phone instantly.. but when it is attached, it will never fall, not even in the worst case.
A bit expensive, but you'll need only one for the rest of your life.
http://www.rammount.com
13 hours ago, topgear said:
Dr @Chaitanya D did you install yours on flat surface like Dr @M.Seidam or on the windscreen?
Mounted on front windshield and another on rear view mirror
On 12/8/2021 at 6:52 AM, Mark D said:
Thanks for the feedback!
will let you know wha I purchase and how it performs.
cheers
@Mark D since you have an F-150 and looking for the strongest one, your best option is base plate bolted to your dash + RAM ball + arm with either RAM X-grip or strong magnetic, see below photos:
Base Plate from https://www.builtrightind.com/products/builtright-industries-dash-mount-2015-2020-ford-f-150-raptor-2017-f-250-f-350
