Audi General Discussion Forum | Audi A1 Forum | Audi A3 Forum | Audi A4 / S4 / RS4 Avant Forum | Audi A5 / RS 5 Forum | Audi A6 / S6 / RS 6 Avant Forum | Audi A7 / S7 / RS 7 Forum | Audi A8 / S8 Forum | Audi Q3 Forum | Audi Q5 Forum | Audi Q7 Forum | Audi TT Forum | Audi R8 Forum |
Sign in to follow this
turmer
Why engine oil looks different.
If it turned black, then its most likely time to change it.
If it turned light color with sticky feeling then probably coolant is leaking inside the engine oil chamber due to head gasket leaking. In this case check the coolant and if it turned milky white color or close to it then for sure head gasket is leaking. Get it fix asap before car overheat and warp the head.
