turmer Posted October 19, 2011 Report Share Posted October 19, 2011 My engine oil looks different? Is it because of the heat of i have to do something about it? Link to comment Share on other sites More sharing options...
fransisaudi Posted October 22, 2011 Report Share Posted October 22, 2011 If it turned black, then its most likely time to change it. If it turned light color with sticky feeling then probably coolant is leaking inside the engine oil chamber due to head gasket leaking. In this case check the coolant and if it turned milky white color or close to it then for sure head gasket is leaking. Get it fix asap before car overheat and warp the head. Link to comment Share on other sites More sharing options...
