FORD MONDEO ENGINE MOUNTING
IF ANY ENGINE MOUNTING IS GONE HOW I CAN UNDERSTAND?
TOTAL HOW MANY MOUNTING IS THERE IN FORD MONDEO 2003?
MY CAR RUNING TIME VIBRATION IS COMING. I DONE WHEEL BALANCING, STILL VIBRATION IS THERE. SO MY DOUTE IS ANY MOUNTNG IS GONE ANY VIBRATION WILL COME OR NOT?
Engine mouting vibration comes during take off only and not during driving. Or while idling at times if more than 1 mounting is bad.
If i am not wrong Mondeo has there mounting, 1 under front side of engine and 2 at the back, little bit aside the engine.
Get the wheel hub checked for slightiest play. If vibration is at specific speed like only from 70-90 and then ok and then again from 110-120 then for sure tires issue. If vibration starts from slow speed then it could be wheel bearing, front axles.
Explain more so that i can help you more precisely.
