RPM goes up n down
Check the alternator supply as it has voltage meter which produces current as per requirement, if its freaky can cause such weirdo behaviour.
If you mean rpm actually goes up and down not just needle, then you need good engine tune having OBD II tool to set the idle at factory setting.
