leak under the timing belt
That leak under timing belt could be normal oil leak and could be from engine head, engine chamber area or crank case (more likely). You cant tight timing belt as to read it you need full day of opening engine front portion. And tightening timing belt has nothing to do with leak. You need to trace the leak is from which place and get that gasket replaced. If its engine head gasket, you in for long and expensive surprise. Sorry bro.
