how do i change fuel filter ?
ben
  • 2 weeks later...
Ok. Replacing fuel filters should be part of your regular maintenance. In case you don't know how to do it, please follow the steps:
1) Relieve pressure in the fuel system. (Make sure you do this for safety reasons)
2) Disconnect fuel lines.
3) Remove fuel filter. You usually need to unscrew the clamp holding it.
Note: Since you are at it, you might also want to replace the pressure washers.
