Wheel bearing problem?
griyaz
My old HR-V is making me terribly mad!
I just can't seem to figure out why this car won't go straight - after I bought it I had everything checked and the tires changed. I even got the wheel bearings adjusted after I found out they were loose but I just fail to understand why my car will not keep in a lane when I am driving. I am sure that the wheels are aligned since I got it checked from more than one place...
What else can be the problem?!
  • 3 weeks later...
Wheel bearing is hard or very tricky to repair as it needs very high precision which i reckon any local shops has unless you got it done from very high profile shop. Its highly advisable to change the bearing if this problem persist and get over with it. These crooked wheel bearing may also damage your axle if you prolong.
