Incident after incident
miked
hello fellas,
Last week one of the spark plugs just shot and it made a loud noise. I shut down the car, took it to Al Futtaim and got a new plug installed. The car seemed back to normal. I brought it home. After a day or two I saw some error codes comes up, I disconnected the battery to wipe out the codes since I genuinely thought that those codes were triggered due to the spark plug incident. Now my car won't start and it has been sitting idle. I checked the connectors, wires, battery, everything ... can't seem to find anything wrong. What can it be?
Yes the ECU might have been affected and plus a compression test might help - it will establish the compression rate on your vehicle and whether or not the car will run efficiently. Here is how you can go about doing it:
http://www.popularmechanics.com/cars/how-to/maintenance/cars-101-how-to-do-a-compression-test-14912158
Another thing, have your battery and engine connections thoroughly checked - something you might have done already.. just a reminder.
