Diagnose oil pressure warning light
The common reasons why you face the check oil pressure light is because of the oil leak, bad oil pump, defective oil pressure sending unit or defective warning light switch.
Whenever you face this problem, you need to check for the oil leak in the engine and oil pump. Sometimes, when there is no oil leak, there is an issue in the oil pump. As mentioned above, you check get the pump or oil pressure sending unit checked.
Oil pressure warning light detects the trouble associated with the engine. Don't avoid this warning light, as it may lead to sever internal engine leaking. This light may pop up because of oil pump damage, but if ignored, the damage inn he oil pump can destroy the whole engine. Adil is right about the causes. I remember one time when i ignored the oil pressure warning light, and later the engine oil had a leak and i ended up replacing some parts in the engine.
  • 1 year later...
