RPM at 0
AudiKid
I have an Audi A3 and I recently have come across the problem where the RPM meter is just stuck at 0. No matter how fast I go or how slow I go it will always be at 0. There is no actual engine malfunctions only the fact that the meter is at zero and is clearly not working. Is this a common problem? How do I fix it?
Seems like the guage is died on you, seek a mechanic and check if they can repair or may be advise who can in Dubai or Sharjah. If not ultimately you got to replace it.
Before jumping on this better check all the fuses and relay are working on it. These electronics are really funny sometime. 2000 dhs problem can get fxied in 50dhs.
By your own, you can only check the fuses and relays to make sure there is nothing burnt/not working, if it is then change those and see if it helps.
More than that checking the instrument cluster for gauge inspection you need to take it to mechanic or rather mechanic first and then electrician.
