Wheel Beering Noise!
Please note if the bearing is making a noise then its definitely wheel bearing failure. Also check when you take a sharp turn. does the noise suddenly changes? If yes, then its definitely serious because if the wheel bearing is failed it may also lead to an accident. So its better for you to take your car to the garage and change it.
