HELP PLEASE, WARNING LIGHTS
Hi, I have a 2008 Jeep Commander 5.7.
3 warning lights are appearing on my dashboard, ESP/BAS, ABS and traction control.
My cruise control does not work and the error message reads service 4wd system. I took the
car to Western Motors and they said it might be the speed sensore but couldn't be sure even
as that was the obly fault code coming up.
The car drives fine but today my check engine light also came on.
Any help or advise PLEASE???
As a first rule, check all loose wires especially under driver seat and check all fuses for making sure that ABS modulator is alive. If that is alive and kicking then everything else is easier and cheaper to fix. Get the Jeep specific computer diagnostic as that will read all error and point in right direction.
  • 1 month later...
  • 2 weeks later...
