Hyundai General Discussion Forum | Hyundai Accent Forum | Hyundai Azera Forum | Hyundai Centennial Forum | Hyundai Coupe Forum | Hyundai Elantra Forum | Hyundai Genesis Forum | Hyundai Getz Forum | Hyundai i10, i20, i30, i40 Forum | Hyundai Santa Fe Forum | Hyundai Sonata Forum | Hyundai Tucson Forum | Hyundai Veloster Forum | Hyundai Veracruz Forum
Sign in to follow this
vasu
Why is the engine oil feeling a bit sticky?
the engine oil is feeling sticky for some reason as this is my usual practice of checking the tyre pressure, engine oil, coolant. i felt that the engine oil is sticky where as the color is some what still the same and didnt find any other problem yet.
When engine oil become little used it tend to get sticky first and then start getting darker and about to change.
Its absolutely normal behavior. If color isn't turned dark then its safe to use.
If still in doubt, better get it changed as it is so cheaper than fuel and cost of damaging the engine you will be better off getting it changed.
what was the reason did you find out.
> use.
very informative.
thanks edison.
