Sonata Service Schedule
2008 Model Hyundai Sonata GLS 6 Cylinder: Service and Maintenance Schedule
6000 Kms
Replace engine oil and filter
Inspect exterior lights
Inspect tire pressure
Check coolant, battery, brake and washer fluid levels
Inspect and lubricate all latches, hinges and locks
12000 Kms
Inspect all drive belts
Inspect vacuum, crankcase ventilation hoses
Inspect driveshafts and boots
Rotate tires
18000 Kms
24000 Kms
Inspect engine coolant
Inspect automatic transaxle fluid
Inspect brake hoses and lines
Inspect front brake pads, rotors and lubricate calipers
Inspect rear brake drums/linings, parking brake (or rear discs/pads)
Inspect exhaust pipes and muffler (after manifold)
Inspect vacuum, crankcase and ventilation hoses
Inspect battery terminals
Rotate tires and balance
30000 Kms
36000 Kms
Rotate tires
42000 Kms
48000 Kms
Inspect fuel lines, fuel hoses and connections
Inspect vapor hose and fuel filler cap
Replace air cleaner filter
Replace engine coolant
Inspect manual transaxle oil
Inspect brake fluid
Inspect suspension mounting bolts
Inspect steering gear box, linkage and boots/lower arm ball joint
Inspect power steering pump and hoses
Rotate tires
Inspect driveshaft and boots
Inspect transfer case and rear differential fluid levels (AWD only)
54000 - Go above again to 6000 Kms service and follow same.
Specific Maintenance Services
Service iridium spark plugs every 42 months/84,000 Km
Replace iridium spark plugs every 78 months/156,000 Km
Replace Fuel filter every 30 months/60,000 Km
Replace fuel tank air filter every 24 months/48,000 Km
Replace cabin air filter every 12 months
Inspect valve clearance every 48 months/96,000 Km
Replace automatic transaxle fluid every 84 months/168,000 Km**
