Save the Fuel
Well for fuel saving, here are a few tips:
  1. if you don't mind the UAE heat, then at below 80 kph open the car windows and turn off the AC, above 80 kph roll up the windows and use your car's AC (research air resistance and drag for the science behind it)
  2. make sure your car's spark plugs are in A1 condition or use advance NGK or any other brands titanium tipped laser plugs
  3. make sure the car's air filter is clean or upgrade your car's air filter system
  4. upgrade your car's exhaust system, make sure you don't use a noisy one or you will get fined i think its around AED 200
  5. use a good engine lubricant
  6. make sure that your tyre pressure is correct, lower tyre pressure uses more fuel
  7. if you can, then don't use car body kits as it changes the aerodynamics of the car and increase air resistance
  8. do not over accelerate, getting to 120 kph quickly means using more fuel. (drive safe)
  9. stay around 110kph and you will be surprised at how much fuel you can save by just going 10 kph slower.
  10. Most important - Make sure your next car is a hybrid :)
Hope this helps
