engine oil leak
Only possible way to run the car until fix is keep topping the engine. If its big leak i advise dont drive, if minor top up will last atleast 2-3 days. As while running car it wont leak, but while idle it will leak more. Secondly there is no other way to stop the leak other than fixing it properly like gasket change, or any other thing change which is broken and leaking.
