Internal coolant leak
Internal coolant leaking is really bad and expensive. Internal leaking is inside the engine where it is difficualt to check the leak and also the repair is not possible. The only solution to stop the leaking is to replace the part. Head gasket and ATF oil cooler are the two major places where internal leaking is noticed.
