too many problems and i need
Spend some time at peace in shade and check all the fuses ad relays and change all the ones that are burnt and make note of it to check after week if it blows off again so that you can see electrcian and tell him this issue and aks him to diagnose everything.
It cud be possibe that these fuses just work fine so you are happy.
Airbag light i doubt will get fix with fuse or relay but horn and beeping for sure will get cured after good work. Airbag light cud be because of loose connection under driver seat, if not you need computer check to find the fault code and then clear it.
  • 2 months later...
