cruise Control
zrenjithz
Do anyone have any idea of fitting an aftermarket cruise control kit to Cerato 2012 model? I badly need one and have found a few recommentations online..
1. Buy an aftermarket cruise control kit and fix it with a technician's help
2. Get a cruise control fitted steering wheel and its just plug and play
Can anyone give some light on the above? i am fed up with the speed cameras i get every week :D
  • 1 year later...
Hi
I don't recommend installing aftermarket cruse control at all however if you need it you can check with the dealer for a retrofit kit or go for scraps and find accident car and take it out it should include steering wheel and brake switch and wiring and later you may need to make programming for engine ECU to enable the function.
