Airbag warning light is on
Massimo
  • 1 month later...
Well if light is one, then that means that SRS system is having some fault somewhere. However its seriousness will be known after getting the proper diagnostic with LR scanner. From safety point yes its serious, but from driving point it is not, and it doesn't affect other part of car. There are many cases that in accident airbag fail to pop but still people survive and vice versa, just make sure you always wear seat belt and avoid rash driving until you get this fixed.
  • 6 months later...
Thank you!
  • 9 months later...
It is probably a glitch in the system, but you need to take it to the dealer and check this issue as fast as you can. Air bags can be very helpful in cases of car accidents and you can't risk to drive your car with a faulty air bag.
