How do i remove the center console arm rest?
gattey
  • 4 years later...
Here is what you have to do:
  1. Remove trim around gear shift (carefully pry up)
  2. remove screw for cup holder,
  3. remove felt pad in lower console.
  4. remove 2 10mm bolts
  5. remove console.
Once I had to do that when my center console cracked and I had to replace it with a brand new one (https://www.carid.com/center-consoles/). First, I thought getting an aftermarket overlay piece that would stick-on, but then I realized, that the sound will not disappear (the cracked plastic piece will give that sound under vibration, when you drive). :?
Edited by LexusMan66
Sharing another detail on the repair
