Sign in to follow this
boneyd
Gear not smooth
Hi Guys
I have ES serirs lexus from 1 year. I had an accident with my car almost 2 months back. After the accident, the gear of my car is not smooth and its really annoying. Can anyone tell me what is wrong with the gear and what shall i do about the same!
It may be because the oil flow in the gear box is not proper. You can go the service center and tell them to change the oil in the gear box.
I faced the same issue once in my car. I asked one of my friend to help me as he had his own workshop. He told me that generally this happens when the oil supply in the gear box is not proper. If you did not get the oil changed in your engine for a longer time, then that can be one reason. Or may be the supply of the oil is not proper in the gear box. What also matters i the quality of the engine oil you are using for your car. Make sure you are using good quality with high viscosity oil, that helps in running the engine and gear box smoothly.
