background noise
kapil
Hi guys
i am having this huge problem with the background noise while I am talking on my bluetooth on my car. The person on the other side of the line hears the background noise more than my voice and its weird because that never used to happen. Does someone have an idea about this issue?
Have you tried re-pairing your device with the vehicle? This is a common problem in all cars with you are using your bluetooth connection. Delete your phone from the bluetooth options on the car and pair it again ... see if this will improve the background noise. Good luckk
Hi guys,
When I had a background noise problem while using my bluetooth during calls I got really mad and searched online for it. Supposedly you can reset the bluetooth system with just a couple of steps. this should be present in the manual as well so do check it before you proceed with the reset process.
1. turn the audio power on
2. Press and power button and audio button simultaneously for 2 seconds approx.
3. '39' is the diagnostic code for the reset so input that when prompted
4. To reset - press the enter button until it shows that the passwords have been cleared.
Cheers!!
