Mazda General Discussion Forum | Mazda 2 Forum | Mazda 3 Forum | Mazda 6 Forum | Mazda CX Forum | Mazda MX-5 Forum
Sign in to follow this
santoddc
shaking while the engine is on
If car is well serviced in time, then its due time to check the car spark plug, HT leads and coil first and then check the fuel filter and fuel pump for any blockage or slow delivery of fuel. If its only shaking and not mis firing then check the engine mounting that may be cracked and causing this slight vibration in neutral, in that case it might also cause some jerk when you shift to gear from neutral.
