car overheating
dolittle
From experience i can say that when you find no system leaks and the water pump is fine as well then the problem is usually the thermostat. Failure in the thermostats mean that they keep the antifreeze from circulating through the radiator ... hence it cant cool down. Ur car might be overheating due to that.
How many km do you have on ur car? old cars with high mileage have clogged radiator cores and usually this problem is not taken seriously but in these cases people end up changing the radiator. Good luck with thatt.
