Throttle body system?
yes you are right about the sensor part, it contains the throttle position sensor and the idle speed sensor regulating the fuel to air ratio inside the engine. These sensors are connected with the engine control computer and provides information on what speed the engine idles.
No you don't have to replace it if it is dirty, there are cleaners available to clean it thoroughly. What you can do is take it out and clean and and place it back ... just make sure that you are aware of how to do it since the last time i did it, my car started having idling problems. However at that time I was cleaning and operating the throttle body and the IAC control sensors. The problem might have been associated with the IAC as well so can't say for sure.
