UAE'S MOST ENGAGING CAR SITE
Doc
Timing belt Replacement
Where to get the time belt replaced???
That is the question faced by most Pajero Owners when they hear of the exorbitant quote by the dealership.
Here’s my story. I own a 2009, 3.8 L, LWB Pajero.
Until 90k,I regularly got all my service done at the dealership, this was because I has a service contract with them . But after that every 5000 -7000, Km I just got Oil and Filter change done at any Adnoc Lube.
When I Reached 120K, I sought a quotation from the dealership for Timing Belt replacement along with 100/120K service. The price they quoted was shocking. AED 4,000 for Timing Belt Replacement, and AED 2,000 for the Service. Total AED 6,000. And this was a discounted promotional offer, according to the sales person.
Since I felt this was exorbitant I kept searching for an alternative solution, by now the mileage had run up to 133k, Last week during a casual conversation , I was referred to Al Azrag Garage in Quassis, Dubai. This Is Owned by Mr Zaffar , a hardcore off-road enthusiast , and Crew and Marshal of Emarat 4X4.
I am extremely happy with their work, at a fraction of what the stealership charges , and would recommend them to any Pajero owner. They kept the car overnight, and I could supervise the work most of the time.
Before I went there, I did a little home work and made out a list of things which I wanted replaced, this I got from the service manual, table for things to replace at 100K and 120K. Also the specification of the Parts/Fluids to replace from the User manual.
For the 3.8 liter 2006 model LWB Pajero
ITEM SPECS
1 ENGINE TIMING BELT MD 358549 1 X 190= 190AED
2 SPARK PLUGS IRRIDIUM TIPPED IFR6B-K 6 X 50 = 300AED
3 AIR CLEANER ELEMENT/FILTER Was inspected and did not need replacement
4 ENGINE COOLANT SUPER LONG LIFE 10.5 LITERS
5 BRAKE FLUID DOT 3 OR DOT 4 Was Not Replaced
6 CLUTCH FLUID DOT 3 OR DOT 4 Was Not Replaced
7 FUEL FILTER MR 529135 1 X 95 = 95 AED
8 TRANSFER GEAR OIL Hypoid GL-3 SAE 75W-85 2.8 LITERS
9 DIFFERENTIAL GEAR OIL FRONT / REAR Hypoid GL-5 SAE 90 1.15 FRONT / 1.64 REAR
10 AIR PURIFIER FILTER IN CABIN Was Not replaced
11 AUTOMATIC TRANSMISSION FLUID ATF SPIII 9.7 LITERS (5 LX 2) 230 AED
12 ENGINE OIL ADNOC Voyager Silver 10W 40 , 5 Liters
13 ENGINE OIL FILTER MZ 690150 1 X 20 = 20 AED
All Parts and Fluids were bought from Authorised Original Parts shops, like (DIVYA in Sharjah or Dubai), but not from the dealership.
DIFFERENTIAL GEAR OIL Hypoid GL-5 SAE 90 was brought from Eppco Petrol Pump. Enoc makes this gear oil in the brand name “zenon”. 4 liter can for AED 72.
Note
I couldn’t find “ TRANSFER GEAR OIL Hypoid GL-3 SAE 75W-85 as specified in the manual ” so I replaced it with DIFFERENTIAL GEAR OIL Hypoid GL-5 SAE 90.
This is your call, You could try to get this from the dealership.
Anyway car works fine, Gears shift well , No problems.
Little research as to what these numbers and Letters refer to. Example :Hypoid GL-3 SAE 75W-85
Hypoid is an abbreviation of hypocycloidal gears and relates to the geometry of the crown wheel and pinion arrangement usually on rear wheel drive cars and vans. The pinion is usually highly off-set to reduce propshaft intrusion into the passenger compartment.
API stands for American Petroleum Industry and GL stands for Gear Lubricant, see below for their definitions:
• API GL-1 Straight mineral oil.
• API GL-2 Mild EP for worm gear oils.
• API GL-3 Mild EP for spur and spiral bevel gears in axles and transmissions. Contain up to 2.7% anti-wear additives
• API GL-4 Medium EP, moderate severity hypoid gears, manual gearboxes. Contain up to 4.0% effective anti-scuffing additives
• API GL-5 High EP, all hypoid axles, some manual gearboxes. contain up to 6.5% effective anti-scuffing additives
• API GL-6 Extra high EP, now obsolete.
EP means extreme pressure and refers to the additive used in gear oils. This additive is designed to stop metal-to-metal contact taking place between transmission components.
SAE stands for the Society of Automotive Engineers.The SAE Viscosity grade are only a measure for the viscosity of the lubricant oils and do not give any statement about the quality and compounds of the motor and gear oilSingle Grade oils are designed for only one SAE field, Multigrade Oils contain several SAE fields.
Summery.
Its time we moved away from dealerships and their cutthroat pricing.
Garages Like Al Azrag ( GPS Coordinates N 25.28902, E055.40527 )are a ray of hope for those of you who want quality work but do not want to get robbed in the bargain. Definitely recommended.
  • Like 4
When you change the timing belt on those engines you should also change the tensioner, tensioner pulley and idler pulley. It's not a difficult job to do but it's time consuming. The alternator, steering pump and AC compressor need to come off. If the bottom pulley is overly tight, you'll also have to take the radiator out to make room for the air gun.
  • Haha 1
So I can see that my Pajero surgerieeeeesssssss experience going long way.....buddy. lol.
On Sunday, God built the Pajero...
in all seriousness, I love the things. I used to hate them with a passion when I lived in my home country. They were all diesels with bad injection pumps and rotten chassis thanks to the climate but here in UAE, they're king of the desert. Sorry land cruiser, go home you're drunk.
  • Sad 1
Hahahahaha yes @ameen. Im still adjusting.
Sometimes I call my parents back home on Sunday morning and ask them why they are still in bed and not at work!
  • Haha 1
After how many kilometers is it recommended to change the Timing Belt??
If we bring the Timing Belt from UK or China weather is it worth it??
How Much will be Total Cost of Timing Belt replacemet with Service is UAE
I would want to change it every 80k or 3 years, whichever comes sooner.
The mitsubishi timing belts are perfectly fine. When it comes to spurious belts, gates is the only brand I trust. Chinese belts may be fine, they may not but usually you get what you pay for. An extra 50 dhs for a quality belt is nothing compared to maybe 1500 dhs for head rebuild if a cheap unknown brand fails.
Cost just depends on which garage you choose but again, you get the quality of work you pay for.  A more expensive garage is more likely to clean things and put them back together properly whereas a cheap garage is more likely to just stick silicon on everything to hold it together.
  • Haha 1
And than there are a lucky few to find @Barry who does quality work at less than the Sharjah garages would charge you.
  • Haha 1
