ESP warning is on and the clock is off
ESP and clock off is separate issue. ESP light is on due to stabilizing the car while on slippery surface or loose gravel or while hard pickup or donuts. Its electronic Stability Program suppose to kick on while it sense loss in traction. It also turns full time on when you choose ESP off and override car w/o ESP for some racing stunts etc.
Clock must be off due to some fuse failure, check all the fuses and replace the one that is blown off.
