duke Posted April 2, 2012 Report Share Posted April 2, 2012 Hi All, I'm a new bee for the forum, I'd like to know if the patol 2000 has a diff. lock? Also what type of differential comes(LSD, Lockable diff.... etc.) in 2000 model. Rgds, Link to comment Share on other sites More sharing options...
toad Posted April 3, 2012 Report Share Posted April 3, 2012 It was completely optional to have diff lock or not in 2000 Patrol GU models. So all GU model having mix cases. LSD rear wheels rotate in opp direction if set free on scissor lift, if you wondering how to find out if its LSD or not? 2000 GU had Open diff in front (Open diff at the front means it's a standard differential like a road car). The rear lsd works well though and will tend to keep both wheels moving when traction is low. Center diff can always be locked in a 4wd. Standard is open front and rear lsd setup. Link to comment Share on other sites More sharing options...
Bulbous Posted April 13, 2012 Report Share Posted April 13, 2012 Patrols don't have center diffs. they are Part Time 4WD Link to comment Share on other sites More sharing options...
daniell Posted April 26, 2012 Report Share Posted April 26, 2012 Bulbous: Does new one's 2010 model also dont have center diff? Its the key to self recovery in sticky spots. Link to comment Share on other sites More sharing options...
