how can i check timing belt?
  • 4 weeks later...
  • 2 weeks later...
Guys would really be helpful if the person who replies would double check their information first before replying...
Porsche Boxsters do not run a rubber timing belt, they have an internal timing metal chain that usually does not require changing.
porsche 4 cylinder engines found on 924s,944s,968s have a rubber poly ribbed belt used to time the valve opening with the car's engine rotation.
so my friend you don't have to worry about your boxster's timing chain.
###PORSCHE NUT EXTREME###
