ajeets Posted August 2, 2012 Report Share Posted August 2, 2012 the front wheels always keep loosing pressure every week almost its not noticeable if checked every day but only weekly basis it is. why this is happening? Link to comment Share on other sites More sharing options...
smartprider Posted August 4, 2012 Report Share Posted August 4, 2012 in the summers the rubber that is the tires expanding and in winters then contract. this process wears of tires and specially when you park close to the pavement that puts pressure to the front tires this even get worse so what you should do for a start is see if you have any punctures that needs to be fixed and if the tires are way too old then i suggest you get them changed. many accidents happen with tires going bad and even if its brand new tires the wrong tire pressure can cause a havoc so please be careful and dont take this lightly. DRIVE SAFE!! Link to comment Share on other sites More sharing options...
ronak Posted August 28, 2012 Report Share Posted August 28, 2012 maybe all you may need is to get them changed and this happens you need not necessarily change all the 4 tires. Link to comment Share on other sites More sharing options...
ajeets Posted March 11, 2013 Author Report Share Posted March 11, 2013 i have rotated the tires tow times and now the mechanic said its too soon too much it will damage the tires and Axel is that true? Link to comment Share on other sites More sharing options...
