CadillacDxb Posted November 9, 2010 Report Share Posted November 9, 2010 Cadillac Maintenance Procedures - Common Additional Services Cadillac Air Filter Replacement The air filter accumulates dust and debris and should be replaced to protect the engine and maximize fuel economy. For optimal engine performance and longevity, replace every 1 year or 25,000 kms. Cadillac Automatic Transmission Fluid Change Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. It should be replaced every 2 years or 50,000 kms. Cadillac Automatic Transmission Fluid/Filter Change Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. The filter should be replaced at this time a well. This service should be performed every 2 years or 50,000 kms. Cadillac Brake Fluid Replacement/Flush Brake fluid accumulates moisture and contamination from component wear over time and unless replaced every 50,000 kms or 2 years, can cause brake system damage. Cadillac Cabin Air Filter Replacement Over time the Cabin Filter(s) will accumulate dirt, pollen and debris which can leak in to the passenger compartment if left unchecked. They should be replaced every year or 25,000 kms. Cadillac Coolant Replacement/Flush Engine coolant breaks down, gets rusty and becomes contaminated with debris from component wear over time and can cause engine or cooling system damage if not replaced every 2 years or 50,000 kms. Cadillac Differential Fluid Replacement - Front Differential fluid breaks down and becomes contaminated with moisture over time and can lead to differential damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms. Cadillac Differential Fluid Replacement - Rear Differential fluid breaks down and becomes contaminated with moisture over time and can lead to differential damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms. Cadillac Drive Belt(s) Replacement Drive belts crack and become glazed over time and can squeak or even break. They should be replaced every 75,000 kms. Cadillac Fuel Filter Change The Fuel Filter becomes restricted as it accumulates debris from filtering the fuel which, can lead to perfomance problems and early fuel pump failure. It should be replaced every 2 years or 50,000 kms in vehicles where it is replaceable. Cadillac Spark Plug Replacement Spark Plug terminals wear down over time and can lead to engine misfires and increased exhaust emissions. Replace according to the vehicle manufacturers recommended replacement interval. Cadillac Transfer Case Fluid Replacement Transfer Case fluid breaks down and becomes contaminated with moisture over time and can lead to transfer case damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms. Link to comment Share on other sites More sharing options...
raoofh Posted October 15, 2012 Report Share Posted October 15, 2012 very informative topic. three cheers. Link to comment Share on other sites More sharing options...
ketan Posted March 5, 2013 Report Share Posted March 5, 2013 this quick reference is really helpful. Link to comment Share on other sites More sharing options...
