window jammed
If you can do it yourself. Open the door inside panel and trim and take out the window assembly unit out and see if it needs change or its gear (teeth) is broken and making window glass stuck at weird angle.
If you cant do these, better show it to car denter or mechanic and they will comment or fix if needed.
  • 3 weeks later...
