jijoy Posted September 2, 2012 Report Share Posted September 2, 2012 My Toyota Prado 2005 model shows a engine light warning on the dashboard when the vehicle is started. It does not turn off. What could be the reason, How can I resolve this. Is it possible to repair from any local workshop or should I take it to the dealer. Link to comment Share on other sites More sharing options...
Amalik Posted September 3, 2012 Report Share Posted September 3, 2012 Get it computer check first from dealer or any local garage and figure what is botering engine to show Check Engline Light. As that will tell you everything that how serious or non serious job is and then you can decide accordingly from where to get it repaired. It could be as simple as loose vaccum causing this. Just open fuel tank cap once and close it tightly until you hear click, in some case if thats loose will also cause check engine light. Link to comment Share on other sites More sharing options...
jijoy Posted September 4, 2012 Author Report Share Posted September 4, 2012 Thanks for the reply. I will get it checked in the workshop. Link to comment Share on other sites More sharing options...
