bashirrahman Posted June 15, 2011 Report Share Posted June 15, 2011 when on breaking the car is making a thud noise. what should i be concern of Link to comment Share on other sites More sharing options...
barron Posted June 15, 2011 Report Share Posted June 15, 2011 get the brake pad and drum checked. Link to comment Share on other sites More sharing options...
saju Posted January 10, 2013 Report Share Posted January 10, 2013 there is not a single good mechanic i have found that dose brake work for Volkswagen Car. Link to comment Share on other sites More sharing options...
bashirrahman Posted March 5, 2013 Author Report Share Posted March 5, 2013 Thanks guys and saju if going to sharjah u will get loads of options Link to comment Share on other sites More sharing options...
jasimh Posted June 2, 2013 Report Share Posted June 2, 2013 May be your brake disc need skimming, its not mechanic problem but the usual wear and tear issue. Link to comment Share on other sites More sharing options...
noorb Posted June 4, 2013 Report Share Posted June 4, 2013 My car is jerking forward on hard braking has this problem go to do with brake problem mentioned below it seemed to me that it dose so that is the reason i am posting this problem here. Link to comment Share on other sites More sharing options...
gshane Posted May 27, 2015 Report Share Posted May 27, 2015 I believe that the discs from the brakes are reminding you that it is time to change the brakes. make sure that the discs are not damaged too. Link to comment Share on other sites More sharing options...
