when should be fuel pump changed
khamil
Fuel pump change depends on type of fuel you are using, In Dubai its good clean and it shouldn't give problem even till 100k km. However if you have been traveling to Oman than i think you should change fuel filter every 40k at least and pump when needed. If you going to Saudi, fuel filter every 10k and wait whenever fuel pump dies soon than later.
  • 2 years later...
Mechanically, when your car starts giving you bumps while driving, that's the time when you should change the fuel pump. My car had a same problem. When you give ignition and your car don't respond to the same or suddenly when your car stops while driving, that means there is a problem in the fuel pump and you need to change it.
