Infiniti General Discussion Forum | Infiniti Q50 Forum | Infiniti Q60 Forum | Infiniti Q70 Forum | Infiniti QX50 Forum | Infiniti QX60 Forum | Infiniti QX70 Forum | Infiniti QX80 Forum
emad
engine overheated
MX 35, 2010 model: The engine seems to be over heated these days. I don’t have much time to go to a dealer to get it checked. So is it possible that I can somehow do something about this without going to the dealer?
if you dont have time, then you check check for any leak in your engine. Overheating generally happens when the oil or coolantis leaking. You can open your engine and check if you can find any leaking in thr.
