Brake fluid
Yes you can. Look for the rake reservoir. When you locate the reservoir, clean it properly before you open it. You will see the brake fluid cap, open it carefully. You can check the level of the fluid from your naked eyes. The level should lie in half of the inch of the cap. If you cannot see it lying till half an inch to the cap, it means it needs a refill.
  • 3 weeks later...
  • 8 months later...
