Brakes are stiff
You should not drive your car in such a situation. As your stiff brakes may lead to an accident. The main reason why this is happening can be because of the brake fade. You need to go the garage and get the brake lining checked. May be the brake lining is too hot and too thin.
Good point. Well brake stiffness is caused also when there is excess air in the hydraulic system which results in pulling the brakes to be too tight. In addition, if there is fluid leak or hose leak in system, that also leads to brake stiffness.
