rajaahumair Posted May 22, 2011 Report Share Posted May 22, 2011 i am loosing coolant faster then i should be there is no apparent leakage that i can figure out so i am a bit clueless here any advise is welcome rgds R.Humair P.S GOOD JOB ON DUBAI BASED FORUM, REALLY HELPS GUYS Link to comment Share on other sites More sharing options...
audxbguy Posted May 22, 2011 Report Share Posted May 22, 2011 First and formost, coolant should not deplet even after years. Lak is the only cause it deplets, if not external leak is found then its an internal leak inside the engine and that is always a bad news with big expense list of 5k -10k of engine head gasket replacement. If thats the case you must be loosing power too tna before and car must be giving white smoke too. Link to comment Share on other sites More sharing options...
