squealing brakes
Squealing brakes is not a rocket science technology. When you hear the squealing or whining noise from the brakes, it means two things:
Firstly, the life of the car brakes is about to end up. In this case, you need to get the brakes changed.
Secondly, your brakes are vibrating. In this case, the absorbent brake plates must be damaged which is creating whiny noise.
  • 9 months later...
I had this horrifying experience few years ago. I was very scared, but it turned out that the problem is not that bad. Of course, it is much cheaper to replace the brakes on time!
