Replacing spark plugs
Replacing spark plugs is easy. All you need is ratchet wrench, the spark plug socket which came with your car and the extensions for the socket which has to be 12 inches. To find the spark plugs follow the thick rubber wire in your engine and you will find the spark plugs. The, pull the wire off where the spark plugs is at the end of it. Remove it carefully without damaging it. Using the ratchet wrench, remove the old spark plug and install the new one. When installing the new one, make sure the diameter and the extension of the old and the new one is same. Now push back the rubber wire inside again. Some belts have the metal cap on top, so make sure to close it properly. It’s done! You changed your spark plugs.
