color codes
Ok. For power, the colors of wire will be yellow, red, black, blue, blue/white and light blue. Yellow is for memory with 12v(+) constant
Red is for ignition with 12v (+) switched
Black is for ground (-)
Blue is for power antenna
Blue/white is for amplifier turn-on
And Light blue is for phone mute. (This is an exception wire only if you are using Sony stereo)
Sure why not. Speakers have these color wires: gray, gray/black, white, white/black, violet, violet/black, green, green/black.
Gray is for right front (+), gray/black (-)
White is for left front (+), white/black (-)
Violet is right rear (+), violet/black (-)
Green is left rear (+), green/black (-)
  • 9 months later...
