halfshaft replacing
Yes you can. You replace the half shaft; unscrew the axle nut which is on the center of the wheel. Just loosen it a bit so that you can remove the half shaft from the suspension. Remove all the old shafts from there. Be very careful when you do that. As per the shape of the old shafts you removed, install the new one with exact same diameter and circle design. Screw the new shafts back and push the half shaft back to the suspension. This is how you do it!
