gear shifting, but not moving
Air bubble generally is formed in antifreeze or transmission fluid sometimes. Because of the air bubble, the air gets trapped under the transmission causing troubles in the performance. Thought the gear will shift but because the air is clogged, the vehicle won’t move. Its pretty sensitive.
